More and newer vehicle are using 5w-20 even alot of the 4 cylinder vehicle.
What are your opinions about switching to a 5w-20 oil in the 3rd gen?
Mobile recommends Extended performance 5w-30 synthetic (15,000 mile oil changes)
Phil
Just use 5W30 like the manual says to, best option in my opinion
You wipe out your bearings if you do. Newer vehicles have tigher clearances which don't require heavy vicostiy oil .
I use 10w-30 on my 3gee and on my 04 accord with the k24 it says to use 5w-20
Yeah, answered my own question. I'm going to go with the Mobil one extended performance 5w-30
Phil
I'd add an oil temp gauge if you're going with a lighter oil. If your temps start climbing, it's time to move back to a thicker oil.
Now, given your climate there, you should have absolutely no problem running a 5W30 oil. If you were in the desert, I'd be concerned. I tend to err on the side of a thicker oil, but we have a higher average temperature here, obviously. In my A series motors, I run 10W40, usually Pennzoil Platinum. Until you get into boutique oils, you really can't go wrong with PP or M1.
I would be wary about the extended oil changes. Some engines are harder on oil than others. Before going to a long interval like 15,000 miles, I'd want to have my oil tested every 5,000 or so miles to see how far you really can go on the oil. It might cost a bit now, but if you really can push out to 15,000 or 20,000 miles on oil, you're going to save in the long term, and because you know the engine can tolerate those intervals, you're not losing engine life, either.
im trying my first batch of 5w30 right now in my new b20a. wonder how long before its all burnt/leaked
main reason for changing to it was its cheaper than 10w30 and i drive to work every day which is 1.5km down the road so the car never really warms up.
ill change it every 5000kms which is like 3100 miles as it gets a raping now and again.
my theory on this 5-20 and 0-20 oil is that the manufacturers want better mpg so they can sell it easier and they don't care if the motor only lasts 50k (but I don't know much about lubricants) :b
Eric
I have Kendal full syn 5w20 in the b20 last oil change, it was marked down super cheap. It seeps out of the drain plug. Its better than dirty spent oil ehh?
I could tell a difference, ran great but I will change it at 2k miles because I think its not good for the cam & tappets, as well what Rendon said too.
The car wasn't driven this summer, no ac lol.
most of the lower weights are for emissions. i know several manufacturers changed their recommendations for 5w20 and 0w20 after they started having tons of cat failures.
dead white and blue
I guess I gotta ask whats wrong with old 10w-40?
I would try the 0W-30 if you currently run 5W-30 with no issues. Anything 0W right now is going to be synthetic. It will help provide quick start and fast warm up. At operating temp it will perform the same as a 10W-30 or 5W-30. Plus, you should see a couple of percentage points if increase in your fuel economy. The 5W-20 (or, 0W-20, for that matter) would probably be fine, too, but I haven't tried that and cannot speak with any authority.
Yeah, the light oils are for easy start ups, fast warm ups, and for emissions. Once warm, the oil performs like a 30W.
Meh, I just use whatever meineke has on special..
i used to be a strict user of 10w30 but have since just started going with 5w20 and 0w20 or whatever honda says to put in the car because i've noticed decreased performance in the fit using 5w20, haven't changed the oil in the element since i got it but i imagine i'll use a 5w20.
dead white and blue
The oil weight recommendations in our owner's manuals are nearly useless now. API oil specifications have gone through many revisions since these cars were new. You can honestly run them on almost any weight of oil that will pump and not blow out the exhaust as "mosquito fog." The original spec on my LXi was 5W-30. I always ran 10W-30 because of my misconceptions about oil. Living in Texas that didn't end up hurting anything. Since I only use synthetic oil I would run the "lightest" weight of oil you can get away with. The current SN spec 0W-20 oils would probably be just fine.
If anyone here is a petroleum engineer or chemist feel free to correct me.
Geez! I miss my Accord.
i run castrol platnum in my camaro with the royle purple filter but i still change it 5000 to 7000 mile. even though you can go 15 on the oil and 25 on the filter but why trust the label
So for my 87 Accord, I could use a 5w-30? I was afraid to divert from what the owner's manual said. I have 158xxx on the car.
I run 10w-30 in the winter and 10W-40 in the summer here in NJ. I've never had a problem using 10W-30 in any of the cars my family has owned. My father preferred using 10W-30 conventional, i use Shell Rotella being that they still put small amounts of Zinc in it last i checked. My father always suggested to steer clear of synthetic with any of the 3 hatches I have owned. Mainly this was a concern with the old seals as synthetic's detergents tends to swell and cause leaks with older vehicles. I thought i heard someone say something about a tri viscosity motor oil, i think it was synthetic but im not too sure or it could have been some new kinda blend that has additives to adjust the viscosity.
3Geez resident body man
Owner of Wreck-less auto body
it also says not to modify anything...
ive done 3000kms with the fully synthetic 5w30 in my B20A now and its still above the add on the dipstick. not bad!
