Is this normal? Should I check the tranny fluid (Don't know where that is lol)? A mechanic friend told me it's not good to change the tranny fluid in a car so old, but he said I could top it off if it got low. What do you guys think?
^ 1990-1993 did this.
You will be fine changing the fluid. I think on these cars there is a little dip stick on the transmission. Or, I could be completely wrong and thinking of a different car.
ONLY USE HONDA FLUIDS.
@Herbert, I just got the Honda yesterdaySo idk.
@Charlie Okay, I will pop the hood tomorrow and have a look, thanks.
i ended up flushing the trans fluid on my 89 lxi hatch at 57,xxx miles was shifting really rough before, now i flushed it twice with AZ-1 honda fluid. Now it shifts fine. It also could be a TV cable adjustment too. But listen to the other members about the honda fluids for things like this. My 87 lxi hatch does not shift as firm and positive as the one in my 89 even after this was rebuilt about a year ago.
just make sure you have the fluid level correct, if you have too little or too much fluid you can do some serious damage to the trans
3Geez resident body man
Owner of Wreck-less auto body
Hmm, Well my car has about 298,xxx miles on it... so do you still think it is safe to change? lol
if you are use to old shit box th350 or th400 trannies, then the honda trannies are quite harsh in the shift
its just the nature on not having a wanky planetary trans.
the honda trannies are essentially a manual but instead on syncros hubs they have a clutch pack. the gear engagement is quicker than a normal auto and so they feel a bit harsh in the shift
id be leery on swapping the fluid with that many miles. Sometimes its best to leave it alone. If you were gonna swap the fluid it would probably be in your best intrest to change the trans filter, but that's a pain to do
there is no filter! well there is a small screen but hardly a service item on these...
They also don't have the same kind of valve body or servos as the old TH350 etc etc... so really there is not much risk in changing the fluid, not the same mindset of experiences compared to typical automatics such as disturbing seals or loosening up some matter inside the tranny by changing to clean fluid.
To add to this, your newer automatics absolutley must have the fluid changed or they will start acting up pretty soon after 50k miles.
I just drain and fill my fluid, do it like 3ish times and it should be almost 100% new fluid.
That and stick a magnet in the hole after you drain, collect all the metal crap inside your transmission (it's usually liquefied)
I'm at 260,8xx miles and it made a day and night difference with my transmission - great shifting, smooth, etc.. No downsides.
