Results 1 to 18 of 18
Thread: lubricating manual shift linkage
    SE-i Sedan 5 spd
    Over the past year or so, I've noticed a subtle but steady increase in the effort required to shift gears. It's not the synchros, as it goes into gear fine, but it's not as easy to make the throws, and not as smooth as it used to be. It's also not bad, but the old liquid smoothness has declined. I replaced the fluid with Honda MTF, and the clutch is adjusted correctly, so that leaves the linkage, I guess. Can I get at whatever's necessary from under the car, or do I have to take off the boot and go down from the top, or both. Thx.
    Re: lubricating manual shift linkage
    you should also put in the polyurethane shifter bushings while you are at it. they are only like 12 bucks.
    LX User Beanshonda55's Avatar
    Apr 2006
    1989/honda/accord/lxi
    lincoln, nebraska
    where can u get polyurethane shifter bushings, im thinking about doing that.
    sry to jack.
    shepherd79's Avatar
    Falling Waters, WV USA
    you can get busings anywere. online or local autoparts store.
    you probably will want to remove the boot and drop the exhaust heat shield to get to the shifter.
    you may also want to buy some plastic bushings. i changed on mine and the travel went down by a lot. it is a lot more presize and smoother.
    Its the crx shift bushings that work.
    My boot is bad where the rod goes into the tranny I use white grease on it when I change the oil.
    If the stupid torque rod that runs along the shifter rod has been hit it could rub it some as well.
    shepherd79's Avatar
    this is what i used on mine http://www.inlinefour.com/ensusshifsta.html they work great. the company has them in stock too, at least when i ordered they did.
    DX User Blazin's Avatar
    Apr 2007
    1987/Accord/Ex-I FI
    Surrey (car theft capitol of Canada)
    Can this be changed from the inside or do you have to have a hoist?
    all you need is a jack and jackstands
    Sep 2007
    Quote Originally Posted by shepherd79 View Post
    you say the bushings for the 84-87Civic/CRX will work on my 88accordlxi?
    or do I get the 88-91Civic/CRX ones instead?
    thanks in advance
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Quote Originally Posted by anubix View Post
    thanks in advance
    84-87 (16.1101) will work.
    CARDONE SUCKS.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    NVM- was thinking of that leaking bushing on the shift rod.
    Sep 2007
    stands r 4 sissies!
    stands r 4 sissies!
    not when all you have is scissor jacks. i wouldnt like a car to fall on my face
    Sep 2007
    why not?
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Quote Originally Posted by LX-incredible View Post
    I was looking on the Energy Suspension website to verify the part numbers before ordering and noticed that the 16.1101 is only listed for the 93-97 Civic Del Sol VTEC and the 99-00 Civic Si (VTEC). The 16.1102 is listed for all of the other models.
    http://www.energysuspension.com/pages/hon1.html
    Are you certain it's the 16.1101? The shipping for me from http://www.inlinefour.com/ensusshifsta.html is as much as the product, so I'd like to avoid paying it twice if I can.
    Mike
    Sep 2006
    Tucson, AZ
    Positive.
    16.1101G / 16.1101R-1 Energy Suspension Manual Transmission Shifter Stanbilizer Bushings Set Honda Civic & CRX 1984-1987
    Options:
    Color: Red / 16.1101R
    CARDONE SUCKS.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Thanks. I found another site with photos and now that I see both it's obvious. I wasn't thinking how large the pin on the bellhousing is.
    Mike
    the 88-91 civic bushings fit also right?
  1. Shift linkage?
    By neo_blue_accord in forum General Engine Swaps
    Last Post: 10-15-2010, 04:11 PM
  2. Customer shift linkage
    By Edison Carasio in forum Performance
    Last Post: 02-01-2010, 01:48 PM
  3. about that damn shift linkage..
    By Accordtheory in forum General Engine Swaps
    Last Post: 09-23-2006, 09:37 PM
  4. Bad shift linkage?
    By pendejo in forum 3geez Accords
    Last Post: 02-08-2005, 09:05 PM
  5. quick help plz - shift linkage
    By racerx in forum 3geez Accords
    Last Post: 08-25-2004, 07:48 AM
