Results 1 to 25 of 30
Thread: cold air intake
    cold air intake
    ok shepard i saw that you did a cold air intake with a bypass filter.
    i live in cleveland so the weather here always sucks will i have trouble
    with a cold air intake?
    does the bypass suck in hot air into the engine?
    i got my stainless 2 inch exhaust with a magnaflow muffler
    sounds great now i need to get the air in.
    also i saw that ppl are putting a high voltage coil
    will that help me at all
    race12001's Avatar
    Sanford NC
    Re: cold air intake
    the coil will smooth out the idle
    Dec. 05-Dec. 06
    Re: cold air intake
    yeah coil just smooths out idle and keeps a nice even spark at high RPMs....the cold air intake will just give you some top end...i lost a bit of low end after puting my CAI on.
    Re: cold air intake
    i dont want to loose any low end
    Re: cold air intake
    Quote Originally Posted by wallacefan
    dude the A20 is one torquy engine...i mean you have 2.0L its better than civics with 1.6.....plus i have alot of mods like adjustable cam gear and its adjusted for top end....it pull hard...i still have plenty of low end if i work the clutch a bit.
    shepherd79's Avatar
    Falling Waters, WV USA
    Re: cold air intake
    1. you should be fine with CAI and bypass filter. make sure you get a real bypass filter from AEM. other ones just suck hot air all the time. AEM has rubber flappers inside. they only open and main filter gets wet and engine creates big vacuum. I also used K&N filter. The picture you saw was for home made CAI. the whole thing cost me a little under $100 to make and made sure it fit right. about loosing low end power, well actually only short ram air have tendency to do that since they are sucking up hot air most of the time, but they do get huge gains on top end. For low end real CAI is the way to go, but don't expect huge gains on top end.
    2. as far as coil goes, it does help smooth out idel and does help to burn fuel more efficienty. a little more spark power doesn't hurt. the only draw back is that ones a year you have to check your spark plugs for gap and wear. I had Nology spark plugs and they worn out within 6 month. the center electrod was gove on all 4 of them, but if you use NGK plugs you will be fine. use NGK plugs for 88-89 Accord LXI they have one step colder plug than 86-87 Accord LXI.
    Re: cold air intake
    Re: cold air intake
    You want one like this one AEM Bypass I have one like your looking at and it's not that good IMO
    Re: cold air intake
    picopop what kind of cold air intake should i put with that aem bypass
    Re: cold air intake
    You can either make your own CAI by checking this thread out Custom CAI
    Or you can buy one from Ebay off of a 5th generation accord, I'm pretty sure that one fits with little modifcation.
    shepherd79's Avatar
    Re: cold air intake
    no way, that is cheap POS bypass valve. that is the one that sucks hot air from the engine bay all the time.
    the intake in that auction is right. so search for that kind of intake without that bypass filter. search for AEM bypass filter.
    the only think you have to do to make that intake work is cut the fender whole a little bigger. to get the bypass filter work you probably will have to cut the main pipe in half and put the filter in the middle.
    MY intake was made by following the HOw to for CAI. i didn't have to cut my fender. i just had to get extra 90 deg pipe to make it the way it is in my pictures.
    Re: cold air intake
    do you hve any recomendation on the ones on ebay?
    Re: cold air intake
    for the intakes, they're all just tubes. what you realy need to worry about is the AEM bypass and a filter. i'd say get a dry flow filter from aem as well as the bypass valve. the 6th gen accord is the one that fits right i believe.
    shepherd79's Avatar
    Re: cold air intake
    actually it is 5th gen accord one that fits with just a little fender cutting.
    i have to agree about filter. make sure you get a nice one. AEM or K&N filters are good filters. I never used Aem so i can't say how hard it is to clean it.
    Re: cold air intake
    Quote Originally Posted by shepherd79
    i believe they are easy since the dry flow you dont have to oil up after you clean it.
    Re: cold air intake
    thats cause you have a 3" cai tube.. i have a 2.5" tube and my torque at the low end is fine
    unfortunately almost all ready made cais are 3" wide so you have to make your own ot make a 2.5" :\
    Re: cold air intake
    oh really.....cuz last time i checked it was 2.5....3 inch would be too big...i never had a short ram on my car so i could not compare but from stock i did lose a bit of low..... like i said i work the clutch a bit and i got it back...i still need to tune my cam gear.
    Re: cold air intake
    i thought it looked like a 3" when i saw it, but it it's your car so i believe u do you have a 2.5" filter or did you have to use a spacer piece?
    Re: cold air intake
    does anyone have any of the tubes on ebay?
    Re: cold air intake
    its a 90-93 integra cold air system....pico and coco had to cut part of it off and put it by the low part cuz the filter was hiting the splash sheild.
    Re: cold air intake
    shepherd79's Avatar
    Re: cold air intake
    i would never lay filter like that. that is how many people suck up water.
    my filter was about 3 inches from the bottom of that plastic liner.
    you may want to lift your filter in the air.
    shepherd79's Avatar
    Re: cold air intake
    yeah that one will work just fine. your best bet would be to take the pipe to a store and find K&N filter that will fit.
    Re: cold air intake
    yeah im planing on geting a real deal filter insted of the ebay crap. its hard to find one that will fit with out the last bend.
    Re: cold air intake
    shepard
    this one says it has a k and n filter
  1. cold air intake help
    By Beanshonda55 in forum Restoration & Custom Fabrication
    Last Post: 09-25-2006, 10:24 PM
  2. Aem cold air intake
    By Ace in forum Performance
    Last Post: 02-10-2005, 10:17 AM
  3. Cold Air Intake Q?
    By Gregs89AccordLxi in forum 3geez Accords
    Last Post: 08-03-2003, 07:37 AM
  4. cold air intake vs short ram intake vs intake
    By 89accordboi in forum 3geez Accords
    Last Post: 11-28-2002, 11:10 PM
  5. Cold air intake
    By ninja2571 in forum Performance
    Last Post: 09-12-2002, 11:23 AM
