I have been using the standard green Prestone coolant. Honda sells their own coolant that is blue (I don't know if the color means anything except from going thru the 500 threads after doing a search on this subject, some of you say the red one is for higher mileage & it has "additives." The blue Honda coolant is "Type 2." Has anybody who used to use the regular green stuff tried switching to the Honda blue Type 2 coolant? I've been following the owner's manual that says use a 50/50 mixture since concentrations of greater than 60% coolant will impair cooling efficiency and are not recommended. It also said low-mineral drinking water or distilled water should be mixed with the coolant. In addition, it says do not mix different coolants & do not use additional rust inhibitors or anti-rust products as they may not be compatible with the radiator coolant. So if I switched, would there be problems?
