So I got this thing for free from a friend's friend, mainly because she didn't know crap about a car. After a little maint., it was running fine again. I'm doing a bit of research on the ride to see what's possible.
Maint:
Complete fluid change (oil, MTF, coolant)
All motor mounts replaced (both ends of dogbone, both side inserts, and front mount)
Air filter
Alignment
Smog check
Pics
My daily grind is an S2000, so that will be the bar to set for this car at the time attack. At <2200lbs it's at an advantage so far, since my Honda Challenge S2k comes in at 2670 wet. Any feedback is appreciated.
I did read through some of the thread and it mentioned that only one person on here actually has an '82 model. This would make me the 2nd?
I whore a couple of other forums as well, mainly Honda-tech, S2ki (S2000 international), and S2000turbo.![]()
