"g-series" are pretty common nowadays..
okay fail i had to look that up. i was thinking of the 5 cylinder ones
its not that im against swaps, and I can def apprieciate a well executed and clean swap like this one, I just think that 6 or 7k is alot of money for say... 200whp?
any updates on this old thread ?
88 Honda accord Lxi coupe
What did u do? because I too am looking to swap my A16A with a H22A, but I want to keep it Auto, since genuinely it was Auto.... please lemme know
it would be easier doing a h22 swap if you're leaving it auto, cause then you don't have tow worry about the clutch setup (the annoyingest problem i had) and the shifter would probably work with very little modification too. only problem i see is the auto gearbox probably being a bit wider, meaning it will be a tighter fit in the engine bay. it will fit though it's been done before
Is this car still running?
I have an 86 accord lx transmission is gone in it an i wanna swap it what all could fit an what all would have to be done to it
