As the title says, I'm going to need to change the oil pan on my '89 in the next couple weeks. I'm getting a bit annoyed at putting a catch pan underneath the car when I get home with it.
As I understand it, I will have to drop the center crossbeam as well as the exhaust off the manifold to do this.
A quick search here suggested not to use anything other than a genuine Honda OEM gasket when I put on the new pan. An aftermarket pan is considerably cheaper than an OEM one, is there any harm in that?
Should I expect to have to change the gasket where the exhaust meets the manifold?
This is one job that I'm really not looking forward to, but the dealer wants about $200 labour to change it. That $200 can buy the rad and valve cover gasket that it needs
Any tips, suggestions, etc. are much appreciated as always.
