Page 6 of 6 FirstFirst ... 23456
Results 126 to 131 of 131
Thread: Megajolt conversion
  1. #126
    Re: Megajolt conversion
    Im sure the Ford coil packs are plenty fine for your average A series, but there is a benefit of separate coil packs. I can't really find a good diagram of the Ford coils to see how many sets of windings they have, but regardless of that matter the coil(s) are very small and the form factor is bad for expelling heat. The 2 post GM coils should run cooler and theoretically be able to handle more dwell before damaging the coil, spark voltage should stay more consistent or just output more. I do plan on getting the car running on the cheap stock Ford coil that I already have, but when I get aftermarket coils I will probably buy the GM coils.
    I do find it odd, looking at MSD/Accel coils I can't figure out which one is better... Depending on where you find the specs the turns ration, voltage, resistance all vary. Like the MSD coil resistance is lower and the turns ratio is higher, but the voltage is lower, actually lower than the Accel Ford coil. MSD GM Accel GM MSD Ford Accel Ford I don't really like the higher primary resistance of the MSD Ford coil, some of these specs are very strange, but I assume a lot of it is them trying to feed you snake oil. The only thing I trust is the resistance, inductance, and turns ratio, those should be specs you can trust buying any transformer device. The MSD GM coil seems the most efficient to me, I don't really expect 45k volts, especially at an rpm where it matters, I do know for sure that about any of these will deliver a stronger spark at rpm than my single MSD Blaster 2 coil.
    The comparison that I would like to make is performance off idle between Megajolt and an old fashioned MSD box. Did you have one before you installed the Megajolt?
  2. #127
    LX User Fixedit's Avatar
    Feb 2015
    Oregon
    Where this baby at
    I know I posted in the progress thread too but this one seems more recent.
  3. #128
    Original posters last post here was 2021 and his last log in was 11/23.
  4. #129
    Feb 2015
    Oregon
    Yeahh I was just looking at that…ah well
  5. #130
    I have his phone number, I should call him and tell him we all miss him
  6. #131
    Feb 2015
    Oregon
    And his car! I remember catching some of these updates when this was fresh
  1. 2ndGenGuy's '81 Hatchback MegaJolt Lite JR Conversion
    By 2ndGenGuy in forum Project Central
    Last Post: 02-25-2015, 04:32 PM
  2. ItzDave's Megajolt thread!
    By itzdave in forum Carburetor Tech
    Last Post: 10-13-2011, 08:22 PM
  3. OBD-I conversion
    By Nik247 in forum Performance
    Last Post: 07-26-2010, 12:49 AM
  4. E85 conversion kit
    By nswst8 in forum EFI Tech
    Last Post: 12-14-2009, 12:24 PM
  5. HID conversion
    By Blaaz in forum Classic Honda Community Chat
    Last Post: 07-06-2007, 09:31 AM
