Results 1 to 5 of 5
Thread: Changing the coolant
    Oct 2002
    89 accord lxi
    omaha
    I am really confused, about all the different coolanst, in my car. Just wondering about changing the engine coolant and changing the antifreeze, or is that the same. i dont know i am confused. Also my heater, does not heat up, it just blows cold air?????? HElp Help it fricken cold here
    maka_RTH's Avatar
    Nov 2001
    '95 Supra, '08 CBR 600RR, '89 LX-i Coupe (R.I.P.), '88 LX-i Sedan (R.I.P.), '87 LX-i Sedan (R.I.P.)
    Orem, Utah
    well, antifreeze/engine coolant = same stuff. i do know that your heat proly won't work if you have no coolant in your system...
    Greg
    1989 LX-i 2dr 5spd (R.I.P.)
    1987 Accord Lx - automatic-carb
    The lack of coolant has nothing to do with whether or not you have heat unless you've run pure water for years and the heater core is now rotted out. I doubt you'd get away with no coolant in Nebraska in the winter.
    If your heater isn't working you could have a faulty heater core. It's up under the dash and works in theory like a radiator more or less.
    There's also a chance that your temp. controls are not working properly, thereby not allowing the flow of warm water or coolant into the heater core.
    Lester
    Nov 2002
    Ridin Dirty in New York
    I think there is a thermostat that id try working on before a heater core, its a big nasty job
    Oct 2001
    87 Accord EX , 5spd , Manual
    for changing coolant /antifreeze check the how to's ( bleed and flush ! )
    MIKE
  1. Changing main coolant pipe.
    By mushroom_toy in forum 3geez Accords
    Last Post: 10-17-2009, 07:18 AM
  2. Changing oil pan?
    By bhad133 in forum 3geez Accords
    Last Post: 07-01-2008, 07:27 PM
  3. A few ?s about changing CV boots
    By Cat3 in forum 3geez Accords
    Last Post: 08-20-2004, 01:35 AM
  4. Changing Belts
    By wallyyfm in forum 3geez Accords
    Last Post: 04-25-2003, 08:02 PM
  5. Changing an Alternator
    By Sts_Angel78 in forum 3geez Accords
    Last Post: 09-05-2002, 09:24 PM
