For 1988 Accord LXi w/ fuel injection & auto trans, the OEM Honda front and rear motor mounts are discontinued and all the aftermarket ones I have seen are 1/2" or so too tall, meaning the engine tilts up on the passenger side end about an inch because the left side mount secures the engine at a fixed height (it pivots upward from there). The hanger rubber mount on the right side then can't be connected (because the hanger spars are now too close together).
Original part numbers were:
Front 50810-SE0-J31 (I think superceded from original 50810-SE0-J30)
Rear 50811-SE0-980
Actual stock, correct distance from frame cross member to engine mounting bracket surface (means does not include stud height) is about 86mm for front and 73mm for rear. At first I thought the aftermarket ones were just higher because the old ones might be sacked out some but that is not the case, the new ones definitely jack the passenger side of the engine up. It seems some sort of part number convergence happened some time ago and they've all now got the wrong height ... well, they are the correct height for some other models no doubt, just not for 88 LXi automatic. You can even find (aftermarket) front ones on eBay with the correct Honda part number (according to the Honda catalog, of course this assumes the Honda part number didn't supercede to an incorrect number before the aftermarket copied it) molded into the rubber but with wrong height. I used "Anchor" brand but like I said others you can find look the same.
Anyone have the solution? If changing brackets is a possibility, I believe most or all from this era are also discontinued, so I guess that'd turn into a junkyard search ... although I've noticed around here (Los Angeles area) there aren't all that many cars in junkyards this old anymore, at least the yards I've been to ...
Thanks for any help
