![Quote](images/misc/quote_icon.png)
Originally Posted by
LiTtLe xOx BitT
When you say cost effective what do you mean? Yea, it will cost you about 3-4k to turbo your 3g safely and use as a d/d, as where if it was a civic it would be about 2k to do the same. But if your talking about buying a 4k motor and the tranny for it, custom axels, custom mounts, custom wiring, the parts to go turbo, plus rebuilding that motor to support boost your going to spend like 7-8k. How is that cost effective? plus since you made your car go faster you should make is stop faster to be safe so a full disc brake setup with some drilled/slotted rotors would help but will cost more. For that same 7-8k you can take your A20 and have a full turbo build done ( by full build i mean built motor, built tranny, clutch, obd-1 swap, manifold, all turbo parts, wiring, etc..) and still spend about 4k. Then take the other 3-4k and do a full disc brake setup, full suspension upgrade, better wheels and tires, plus do cosmetic things that make the car look better like new paint, body work, tint, interior work, audio system, etc... Basically what im trying to get at is this. You can spend 8k and have a older not so nice looking car with old/worn parts and a turbo JDM B18, or you can have an older great looking car with all new and performance parts throughout the whole car with a turbo A20 for the same price. Which one do you think is cost effective?? Plus if you go with the second option of sticking with the A20 and all, by the time your done your car will basically be new, plus it will be turboed, have great handling, look great, etc. which in my opinion getting a car like that isnt bad for 8k, plus still has that old school look to it. If I had a 3g with 8k to spend then thats definatly the way i would go, but thats just me.
