Results 1 to 7 of 7
Thread: Passenger Side Transmission mount install. 1989 Accord
    Dec 2013
    1989 Honda Accord Lxi 2 Door Coupe; 1989 Prelude 2.0si
    Seattle, Wa
    Hello all. I tried to find some info online but havent had any luck. Its for my 1989 Accord Lxi. I noticed the Rubber mount next to passenger fender is torn & Ive ordered a new mount. Im thinking just jack up the transmission, remove rubber gasket install new one. Is it easier to undo the bolt slip it into mount then reattach? Thanks ahead of time for any advice
    Dec 2013
    Seattle, Wa
    Re: Passenger Side Transmission mount install. 1989 Accord
    Thanks I figured it out....
    Im glad you did because I never have seen a mount like that on an Accord transmission.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Yeah, that looked like an exhaust hanger... So real curious what you did
    Dec 2013
    Seattle, Wa
    Maybe its a transaxle mount? I put a jack under the engine area to which it was bolted to, lifted her up a hair to relieve tension. unbolted the 2 bolts which hold the lower mount. Removed damaged rubber mount, Rebolted mount plate back to AT with mount attached, slipped upper mount slot into upper pin, lowered jack & that was it. Ill try to post a picture soon.
    https://www.ebay.com/itm/28286471113...iABEgKMVPD_BwE
    Dec 2023
    1989 Honda Accord LX Sedan
    Kentucky
    Clicked on this as I am replacing motor mounts. This rubber piece sits under the transmission.
    Ah yes its underneath attached to the cross member.
  1. Replies: 5
    Last Post: 09-06-2014, 10:53 PM
  2. 94-95 Accord Rear passenger side OEM Tail lamp.
    By SharkyX in forum Trading Post
    Last Post: 04-20-2004, 04:34 PM
  3. Passenger Side Mirror
    By factorVIII in forum Trading Post
    Last Post: 07-08-2003, 04:34 PM
  4. Passenger side leak
    By Mac in forum Performance
    Last Post: 06-10-2003, 05:19 PM
  5. WTB: Passenger Side Marker Lamp '89 Accord
    By ELM'sLX+CHL'sDX in forum Trading Post
    Last Post: 05-28-2003, 07:11 PM
