Results 1 to 5 of 5
Thread: Newbie w/ 89 Accord LX
    Dec 2023
    1989 Honda Accord LX Sedan
    Kentucky
    Hello All!
    I am new to 3geez. I have 1989 Honda Accord LX with the Weber Swap (38/38).
    I'm needing help with setting up my A/C with the Weber swap. Also, needing help setting up my Cruise Control with the Weber swap. If anyone can point me to the right thread or offer advice I'd be very appreciative.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: Newbie w/ 89 Accord LX
    Both should just work, what's the issue exactly?
    Dec 2023
    Kentucky
    The AC works fine while moving, but sitting at idle it causes the car to idle rough. I noticed on the original vacuum diagram for the original Kiehin Carb that the AC had an Idle Boost Valve Solenoid hooked to the original Carburetor, but the Weber 38/38 doesn't have a spot to hook up those lines for the AC.
    As far as the Cruise Control goes, when I swapped the Carbs it stopped working. Ive ordered a new Brake Switch, so maybe thats all it was.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    My car idles fine without any idle boost. Check your engine mounts
    Dec 2023
    Kentucky
    That's what someone else had mentioned. Ive actual had instances when on an incline where it doesn't vibrate nearly as much. Could be what it is
  1. 81 accord newbie
    By pavbo10 in forum Newbie Introductions
    Last Post: 03-01-2012, 12:14 AM
  2. Newbie w/a 87 Accord
    By smoothcriminal in forum Newbie Introductions
    Last Post: 03-20-2011, 02:44 AM
  3. Hi newbie 89 accord dx
    By paulwwww in forum Newbie Introductions
    Last Post: 10-01-2007, 11:30 PM
  4. Newbie 88 Accord LX 4D
    By Alien 88 LX in forum Newbie Introductions
    Last Post: 08-01-2003, 11:45 PM
  5. i am a newbie........with a accord
    By 87 HB in forum Newbie Introductions
    Last Post: 07-25-2003, 01:43 PM
Tags for this Thread
