Page 5 of 5 FirstFirst 12345
Results 101 to 109 of 109
Thread: Progress thread
  1. #101
    Nov 2017
    Re: Progress thread
    You can only do this if you stick a roots blower on top with a giant scoop. That would be epic!!!
    In all seriousness though, I'm thinking in much the same direction. The domestic aftermarket has so much awesome stuff that interchanges and works with everything else so well. And in the import scene stuff is so hard to find, doesn't tend to play well with other stuff and is a giant headache to set up. That leaves aside the increasing scarcity of replacement parts for the 3g. If I can retrofit the domestic aftermarket stuff onto my 3g, then all those problems disappear.
    Well some import stuff can fit onto other imports. But the reason you can’t really use any domestic aftermarket on our imports is cause of metric/inch. And most of our stuff is 4 cyl, and their’s are v8’s. Solution? Designing adapter plates.
  2. #102
    Jun 2010
    Re: Progress thread
    Old girl kept door to door with a 7th gen coupe on the way home from work. I know it's bad but he challenged me lol
    Ran over a grocery bag the other day and it stuck to my exhaust pipe, now it smells like burnt plastic >.<
    Originally posted by ShiRen:
  3. #103
    Jun 2010
    Re: Progress thread
    Speedometer fixed! I know how fast I'm going again lol
  4. #104
    Jun 2010
    Re: Progress thread
    Had a funky ass noise pop up last night that sounded like a rod knocking. freaked me out but turned out to be the EGR pipe had come loose and was rattling around. Almost had a heart attack thinking it was getting ready to blow up lol
    Couldn't find a plug to fit the pipe mounting bung so had taken the old pipe and cut it, crimped and welded it shut. It started to back out and was making noise hitting the motor mount bracket.
  5. #105
    Re: Progress thread
    I plugged the manifold with a bolt but I cant remember the thread. Never had a problem running wise after.
  6. #106
    Jun 2010
    Re: Progress thread
    Yea, I was wanting to do that or a screw in plug but couldn't find anything around here. Even went to a nut and bolt store with the header and they didn't have anything to fit. So did the old quick and dirty. Welds are holding up but apparently it wants to unscrew on me. May tighten it back up and throw a tack weld or two on it.
  7. #107
    B0CKS's Avatar
    Jul 2016
    1988 DX Coupe
    Detroit MI
    Re: Progress thread
    OldBlue is right! The EGR on the manifold can be plugged using a trans fill plug. They thread right in. But hey, if it works, don't fix it!
    [SIGPIC]
  8. #108
    Jun 2010
    Re: Progress thread
    Ignition switch finally went. Had been acting up for a while now but got to the point it wouldn't connect unless you held it at a small spot. Took it apart and filed the contacts clean, put 'er back together and works like a charm.
  9. #109
    LX User Fixedit's Avatar
    Feb 2015
    Oregon
    Re: Progress thread
    Hey man, do you have an updated/current thread on this build?
    I got a Rowland intake and a couple of DCOE 40's recently for my hatch that already has a 272 cam and Weber 38 setup.
    I'd love to know more about your throttle linkage setup and catch can. Plus, didn't you end up getting an adjustable cam gear? That Megajolt thread is yours isn't it, I'll go read up over there. I'm more apprehensive about ignition mods but I guess I gotta leave my comfort zone sometimes.
  1. '89 Accord LX-i progress thread
    By 3geeSlagle in forum Classic Honda Pics & Videos
    Last Post: 08-04-2012, 10:02 PM
  2. frantik's suspension progress thread
    By frantik in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-23-2008, 03:45 PM
  3. Victors turbo non-progress thread
    By SQ is the SQUAD in forum Forced Induction
    Last Post: 02-17-2007, 06:35 PM
  4. The Progress Thread
    By Tomisimo in forum Classic Honda Community Chat
    Last Post: 01-26-2007, 03:14 PM
  5. Official 3G convertable progress thread
    By cvergi01 in forum Classic Honda Community Chat
    Last Post: 05-14-2005, 11:38 AM
